It is currently Mon Nov 23, 2026 4:31 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
 Post subject: Isolate dual batterys
PostPosted: Tue Feb 03, 2004 9:02 pm
Sence I got carryed away with audio, guess I'm trying to forget my age I've added two optima deep cycle batterys one for left chanels and one for right chanels plus the dedicated start run battery also a smaller hidden backup battery for the alarm system that makes a total of four all are isolated and charged by the alternator. if the start battery cable is cut a relay kicks in the hidden battery and the alarm and pager go off I plan to get a start selector switch installed so I can jump start myself using eather of the audio batterys Insidentaly I get some real clean thumping without useing any of those expensive capacitors. Given up plans of raceing a pickup with a six. but the 74 GremlinX is coming allong nicely It will sport a 258 with 4spd. 12piont roll cage subframe connectors and a tranglulated four link coilover rear. just got the disk brakes and drop spindle adapters done the engines in the shop and a 77 Amx Hornet has donated its front end, spoiler and wheel flares I think I can have this car done for the Robertson moters show in Salem Oregon this summer, and it will have only one small optima rear mounted battery useing inexpensive cable from a welding supplyer. Bruce J.
78b4ramSnortbed/6
