It is currently Wed May 20, 2026 3:17 am
PostPosted: Tue Sep 09, 2014 2:06 am
Is there a chart that tells you how much to turn each bolt?
For example, the FSM for my Toyota truck has a chart to determine how much to turn each bolt.
Your check your alignment for 'before' (say +1 camber +1 caster), then move along the chart to what you want ( -.5 camber +2 caster) and the chart tells you how much to turn each bolt ( +2 marks front -1 mark rear (I just made these up, don't have manual at moment)).
It gets you close, but it's better than guessing........
PostPosted: Tue Sep 09, 2014 7:31 am
I have never seen any such cheat sheet, nor have I ever noticed any markings on the cam bolts themselves.
:shock:
