It is currently Fri Jun 19, 2026 12:34 am
PostPosted: Tue Jul 16, 2013 7:11 pm
Okay, as a bunch of you have seen I have a 72 Dart Swinger. It definitely needs some work. I replaced a bad fuse (C/LTR, so I assume it was cigarette lighter mainly, but the dome light also kicked on) and did all my electrical tests.
Working:
Turn signals Front and back.
Rear Side marker Left and Right
Brake Lights
Reverse Lights
Not Working:
Headlights
Parking Lights
Front side markers left and right.
So the conclusion I've come to is that something is wonky in the front end area. I've eliminated the issue being the switch since the rear's work, am I wrong? What should i check first?
PostPosted: Tue Jul 16, 2013 7:29 pm
Okay SUPER odd. I accidentally left the lights all on when I cleaned up what I was doing and came inside. about 20 minutes later I let the dog out to Pee and the headlights and front side markers and parking lights were all working. They turn on and off, high beams and low work.
So Will they stop working after they "cool down" again. What is causing that?
 Post subject: Sounds like.
PostPosted: Tue Jul 16, 2013 8:10 pm
Sounds like you might have a bad ground at the wiring harness for the headlights and marker lights...time to find it, scrub it with a wire brush and reconnect it...if it's shorting to make the connection another route something may go puff after a while.
FYI.
PostPosted: Tue Jul 16, 2013 8:40 pm
Will do. I think i see the ground post. Its between the bay and the grill area. Its missing the screw/bolt, is just barely touching it... Anyone know what size it takes? I tried the few spare screws I had in my toolbox and all were too big or too small. Maybe a bolt and nut instead?
PostPosted: Wed Jul 17, 2013 8:38 pm
Either will work, but it's more important to clean the hardware thoroughly where it bolts together and where the ground post bolts to the sheet metal as well.
Use some grease on those connections as well, and you'll never need to worry about them again.
Oh, and welcome to the wonderful, wacky world of intermittent failures!
BC
 Post subject: But it does depend...
PostPosted: Wed Jul 17, 2013 9:04 pm
Either will work,
Well it actually depends on the connection, My '67 had a 3/8" self tapping fine thread body screw behind the headlight buckets as the ground connection. The 70's A-body improved this by welding a thick square metal nut to the radiator support and the ground was a 1/4" NC tapered body bolt similar to the radiator mounting bolts (but without the fender washer).
I can tell you if it's the welded nut, that will be like driving a #10 tek screw through 10 gauge plate...
Can you take a picture of the location so we can be more specific?
PostPosted: Thu Jul 18, 2013 9:02 am
It sounds like its the welded nut scenario, I'll take a nice hi-res picture when I get off work to confirm.
PostPosted: Thu Jul 18, 2013 8:19 pm
Here is the photo. It was a welded nut. I stopped at Lowe's and got a sanding block and cleaned up the nut and the wire loop from the harness, plus a 1/4" bolt as described. Fit right in there nice and snug. Lights come right on now!
 Post subject: One more down...
PostPosted: Thu Jul 18, 2013 10:23 pm
One down, more to follow!
:wink:
 Post subject: Re: One more down...
PostPosted: Fri Jul 19, 2013 9:27 am
:wink:
Yep, Hoping i can convince my girlfriend to let me have a few hours tonight to swap the gauge cluster out so i know if there are any wiring issues or if the problems were all the gauges themselves. Plus I have my tach to put in (Not sure where I'm gonna mount it yet). She is not going to be a happy woman.
1968 Plymouth Barracuda [Daily Driver]
1972 Dodge Dart Swinger [Lent out as Daily Driver to a friend]
2010 Challenger R/T 6 Speed
PostPosted: Sat Sep 13, 2014 10:04 am
at least the transmission lights at the push buttons are working
any ideas where this issue rest?
 Post subject: More info: Dodge Dart 64
PostPosted: Sat Sep 13, 2014 2:03 pm
Was saying the headlamps don't come on
Tail Lights are working, turn signals working
interior knob twist turns on interior courtesy floor light
and the dimmer works for the panel lights
seems a bit simple for an answer and the board is always helpful on this stuff
