It is currently Fri Oct 16, 2026 6:39 am
Should I reproduce sedan sail panels?
Yes 80%  80%  [ 4 ]
No 20%  20%  [ 1 ]
Total votes: 5
PostPosted: Mon Aug 25, 2014 3:00 pm
I was tearing apart my Dart to restore it, and when I removed the headliner the panels behind it were in excellent shape. I think it would make 4-doors more restorable and make owning a sedan a little less stressful. These panels fit 1967-71 sedans with the fabric headliner, not like 72-76 with a molded one. I am only exploring this and want to see if it would be popular.
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Wed Sep 03, 2014 5:56 pm
Yyyy
PostPosted: Wed Sep 03, 2014 6:11 pm
Im not sure what a sedan sail panel is.....
PostPosted: Thu Sep 04, 2014 5:02 am
They are located on interior of the most rearward side pillar supporting, and framing the rear window in a metal roofed car. In other words, it’s the structure supporting headliner material which is attached to on interior vertical surface of that pillar.
PostPosted: Sun Sep 07, 2014 8:19 am
Lol took long enough XD I had given up hope :P Sorry...
PostPosted: Mon Sep 08, 2014 6:07 pm
Bump
PostPosted: Sat Sep 13, 2014 4:33 pm
I have created a prototype set of sail panel boards I will try to post pics soon.
