It is currently Fri Feb 28, 2025 4:49 pm
 Post subject: Dipstick oring?
PostPosted: Sun Sep 07, 2014 11:10 pm
Can anyone tell me if there is an oring intended to sit just below the collar of the '66 style dipstick and what size would be appropriate?
Seems my dipstick has a slight recess just below the collar that might be for an oring or just some byproduct of the manufacturing process.
'66 Dodge Dart
 Post subject: Re: Dipstick oring?
PostPosted: Thu Sep 11, 2014 3:19 pm
Car Model: 1964 Valiant V200
I have several and none have an oring.
PostPosted: Thu Sep 11, 2014 6:10 pm
I put a dab of RTV on the dip stick tube end that goes in the crankcase..
PostPosted: Fri Sep 12, 2014 6:11 am
O-Ring on the dipstick tube? Are you talking about the dipstick tube for the transmission? :?
1964 Dart GT
PostPosted: Sun Sep 14, 2014 7:48 pm
Not the dipstick tube but the actual dipstick. All modern cars have 2 or 3 orings on the dipstick to ensure it seals well against the tube. Our transmissions also use dipstick seals. I know other cars of the era have some means of sealing the oil dipstick (for example, 442s have a rubber sleeve on the dipstick).
This makes me suspect that just below the collar of the engine oil dipstick, in that small indented section, there should be an o-ring or something to help seal the crank case. If not, I guess that's fine too, but if I'm supposed to have one I'd like to get it on there.
'66 Dodge Dart
PostPosted: Mon Sep 15, 2014 5:26 am
No "O" ring.
Modern cars are fume sealed as part of government hydrocarbon containment among other reasons.
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 16 guests
