It is currently Thu Mar 06, 2025 9:14 am
PostPosted: Tue Sep 23, 2014 1:54 pm
hello this is my first post.
i just got a 1970 dodge dart.
225 motor
i rebuilt it and i started it up and theres a loud clattering almost every cylinder
only thing i can think of is rod bearings
is there supposed to be room for the rod to move from side to side on the crank side?
PostPosted: Tue Sep 23, 2014 2:30 pm
6 Pack Dart
Did you put the main bearings in with the holes toward the block or does the rods have a lot of side to side play? You may have a forged crank with rods from a cast crank.
Richard
PostPosted: Tue Sep 23, 2014 2:37 pm
there was ALOT of side to side play on the connecting rods,
PostPosted: Tue Sep 23, 2014 2:39 pm
and is there supposed to be a lot of oil splatter when i open up the valve covers i wasnt getting ANY oil to the top of the head
PostPosted: Tue Sep 23, 2014 2:58 pm
6 Pack Dart
Not a lot of oil unless you are at a very high rev. It should be a very slow flow the rockers will throw oil at high revs.
Richard
PostPosted: Tue Sep 23, 2014 3:15 pm
Rod big end side play should be around .006" to .012" (from my early FSM). Did you measure the side play? I.e., how much is 'A LOT' ??
What did you do/change in the rebuild? Do you know if this was the original 1970 engine?
And have you adjusted the valves yet? As above for the oil in the head; just seeping out of the rockers at idle.
PostPosted: Tue Sep 23, 2014 5:20 pm
Oil pump gasket maybe leaking allowing air to be drawn into the oil pump inlet check the gasket fit to the pump and the block.
Brian
63 Plymouth Valiant Wagon
PostPosted: Tue Sep 23, 2014 7:14 pm
How much oil pressure are you getting?
PostPosted: Wed Sep 24, 2014 12:14 am
yea the rod play was atleast 2 mm side to side.....
i used std size bearings... i thought it would be ok.
i think it is the original motor. how do i check?
im probably just gunna pull the engine and drop a 360.
PostPosted: Wed Sep 24, 2014 12:15 am
pm sent dodge doctor
PostPosted: Wed Sep 24, 2014 8:43 am
Was the car running when you got it? What is the engine"s history?
Are the connecting rods you used during the rebuild the same ones that came out of the engine or did the con rods get swapped with something else?
The reason I ask is that the 225 slant six connecting rods change to a narrower width, when the engines started using a cast crankshaft.
You may have cast crank rods on a forged crank,... that would lead to a lot of rod journal "side play" and running noise.
PostPosted: Wed Sep 24, 2014 9:27 am
2mm = .080" !
PostPosted: Wed Sep 24, 2014 9:44 am
6 Pack Dart
Did you mike the crank to see if it was really std. not undersized??
Richard
PostPosted: Wed Sep 24, 2014 11:35 am
bearing mix....
