It is currently Thu Jan 01, 2026 8:26 pm
 Post subject: Dual Electric Fans
PostPosted: Wed Sep 17, 2014 1:17 pm
So after my accident I noticed my mechanical fan is bent back. I purchased a set of dual 10" electric fans and I have found several temperature based kits to control them. My question is what temperature sender do you use? Is there a way to get the temperature to the dash and to control the fans?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Wed Sep 17, 2014 5:28 pm
Get an adjustable temperature switch.
PostPosted: Wed Sep 17, 2014 6:49 pm
im running something like this.
http://www.ebay.com/itm/FLEX-A-LITE-ELE ... 55&vxp=mtr
works pretty good. hasnt given me any trouble yet.
PostPosted: Thu Sep 18, 2014 12:14 am
I'm not a fan of the "divorced" type sensors... the one that don't actually touch water. Tried one once.... just seemed too sensitive to air movement from the fan, you had to find the right spot on the rad that would expose it to the heat but not have the air move across it so that it was prematurely cooled. Which was pretty much no where.
Get the type with a stock-type screw in sensor. Put it in place where the stock sensor is. Then move the stock sensor to the top rad tank if your rad has a threaded bung there. Some heads have multiple sensor holes. Push comes to shove you can drill & tap the thermostat housing. Just be aware that now the stock temp gauge won't show you warmup progression and will only be accurate after thermostat opens.
This may work for you and is adjustable. If you piece together your own sensor and relay you may be able to do it cheaper. About the sensor temp - you'll get a different answer for every person you ask. It will also depend on which thermostat you use. I'd say maybe 10deg or so above thermostat - for example if you use a 195, you'd turn it on at 205 and off at 195 so the thermostat stays open and engine won't cool off too much.
PostPosted: Thu Sep 18, 2014 2:33 am
I use a sensor like that on my Toyota truck.
Back side of radiator (not thru fins)
near inlet
upper corner
It's in a dead spot air flow wise......
PostPosted: Fri Sep 26, 2014 3:53 pm
I just use a stock GM 210 degree sensor screwed in the top of the radiator. GM used them on many models for many years and are very common.
PostPosted: Sat Sep 27, 2014 11:16 am
Drill and tap head temperature sending unit hole for common chevy sending unit. Use shop vac to suck metal chips when you are drilling and can be done in car quite easily. If you can borrow correct tap size cost will only be a little time. Search Summit racing or Ebay for type of kit you want .
PostPosted: Sat Sep 27, 2014 11:58 am
So what car/model are you asking for to get this 210? Do they make different temperature ones?
Thanks,
Rick
PostPosted: Sat Sep 27, 2014 9:14 pm
I'm using the stock sender for the temperature gauge, and a Wells TS217 switch in an inline fill adapter spliced into the radiator hose.
Not quite optimal, but it does work.
PostPosted: Mon Sep 29, 2014 7:07 am
I've gone through many of those over the years. They don't hold set temp very well either. I would never use again.
PostPosted: Tue Sep 30, 2014 9:19 am
I have never replaced the thermostat switch in the last 15 years or more, Wells TS217, 3/8" NPT, two terminal. Most of the off-road guys out here use this switch in their jeeps. It is also a stock switch found in GM vehicles in the 90's from Cameros and Firebirds to full size cars.....like Monte Carlos, trucks, etc...
Very simple, screw it in the radiator tank after taking out the vacuum switch...and works well when you need it like when stuck in rush our traffic for hours. A very inexpensive set up that is basic and stable and water can't hurt it. Some Flexi-Lite units I have had burned up and did not last long. They stop working if they get any moisture in them during the rainy winter months.
PostPosted: Wed Oct 01, 2014 5:44 am
Thanks for the tip on that temp switch, folks. I will try that too.
PostPosted: Wed Oct 01, 2014 3:09 pm
Summit and Jegs carry many other screw in temp switch ranges, 195, 180 etc. I have a spare in the other side just in case....wired in parallel.
PostPosted: Wed Oct 01, 2014 3:32 pm
Best bang for your buck will be any DIY! All you need is a fuse (or breaker), a 4 or 5 pin relay, a little bit of wire, some connectors and the temp switch of your choice. Im a fan of the one wire switches for simplicity reasons, they just close the ground for your relay at the set temp...
ALOT will disagree with me here, but I like to wire mine using full time power to the relay and no "switched" wire. This will allow the fans to run for a short time AFTER the engines off if its still hot enough to keep the temp switch in the closed position... Just like the "run-on" feature on practically ALL modern cars.
"if it aint broke, fix it till it is"
78 Plymouth Volare Super Six wagon
89 Volkswagen Golf GTI 16v
92 Chevrolet K1500 5.7
98 Ford Escort ZX2 zetech
PostPosted: Thu Oct 02, 2014 8:32 am
Agreed!
The last 15 years or so I have never had any heat soak issues since installing the electric fans with this feature. Nice to have....!
