It is currently Wed Aug 12, 2026 11:00 am
Post new topic  Reply to topic  [ 97 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Fri Sep 12, 2014 10:41 am
Glad to hear the trip went well, except for the pump hiccup. Nice work.
PostPosted: Sun Sep 28, 2014 8:41 pm
Have you considered putting your truck on a chassis dyno or a drag strip to see how the successful set of modifications does in the performance arena? I'd be very interested to see some hard numbers with related boost information for that test.
I have a lot of friends who are very interested in what you have accomplished here. Keep up the excellent work!!!
Bill, in Conway, Arkansas
1964 Valiant 4-door sedan, 225 turbo/904
PostPosted: Tue Sep 30, 2014 3:05 pm
Ultimately I plan on getting some dyno runs, I am currently building a water/air intercooler that will sandwich between the bottom of blower and intake.
PostPosted: Tue Sep 30, 2014 3:33 pm
I have an 87 short wheelbase with a slant in it. Would love to run an upgrade like you have done. Ever consider selling the adapters needed to make this work?
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue Sep 30, 2014 3:45 pm
Could you elaborate on the intercooler? I thought this couldn't be done with a draw through setup?
PostPosted: Tue Sep 30, 2014 4:12 pm
I am using a heat exchanger from an 03 cobra terminator, as well as the pump. I will be using a custom heat exchanger just below the blower , I will build a storage tank and run engine ice in the system. It will work very similar to this.
http://teaguecustommarine.com/em0011/su ... ooler.html
PostPosted: Tue Sep 30, 2014 10:09 pm
Would something like the maine 2bbl waterjacket manifold work for that? then you could make adapters for it im assuming?
PostPosted: Thu Oct 02, 2014 2:30 pm
Here is my heat exchanger, It fits perfectly into the bottom of the super charger and has a surface area larger than the opening of the blowers outlet.
I will plumb it to a storage tank , into the electric Cobra terminator pump, then to the larger heat exchanger in front of the radiator, then cool engine ice with go threw this and repeat the process. should drop temps and aid in detonation, might even bump up the boost!
PostPosted: Sun Oct 12, 2014 1:58 pm
decided to go even bigger, going to adapt a 112 supercharger onto this engine.
PostPosted: Sun Oct 12, 2014 2:55 pm
PM on the way
PostPosted: Thu Oct 30, 2014 5:43 pm
I just happen to catch one of the videos on your truck and was blown away! Very impressive in deed. :D
By chance will you be installing a header on the truck soon? Not sure I saw one from your latest pic's.
'63 Dodge 330 '65 Barracuda '74 Dodge W100
PostPosted: Thu Nov 20, 2014 6:59 pm
Right now I have the truck torn completely down to the frame, in the next few months it will go through a complete upgrade.
here are a few renderings of the direction I am going. Going to call it the HellCab! It will have a Cuda style front grill and look. airbag suspension, cleaned up the rear bed rails, sides,tailgate and an aggressive stance.
PostPosted: Sat Nov 22, 2014 6:32 am
W 8) W,,that is absolutely nuts,,
post on the progress..
PostPosted: Sun Nov 23, 2014 8:42 am
here is a little update, nice thing about using the renderings is we can build and test pats and the look before cutting and grinding.
PostPosted: Fri Oct 02, 2015 7:07 am
Hi all the way from South Africa. Matt I hope your build is moving along nicely.
You are one of the main reasons why I joined the forum, I have a GM M90 on its way to me from the States which should be getting to me next week.
I am wanting to go for a draw through (Wet) system similar to yours and was wondering how your setup is still running.
Also to hopefully confirm some aspects regarding running the M90 wet. Look forwarding hearing from you.
Cheers
