It is currently Mon Mar 17, 2025 9:49 pm
PostPosted: Sat Oct 11, 2014 1:38 pm
I have a super six in my 70 Dart. Previous owner installed at some point. I don't even know what year it is other than it has the 2 bbl carb set up and the newer style peanut plugs. Ignition is points and condenser. What should the points, dwell and timing be set up at? thanks!
 Post subject: Stock...
PostPosted: Sat Oct 11, 2014 9:44 pm
There is no points distributor data for this setup, you can set it stock for your year dart, and hope for the best...an EI setup would get the best tuneability and a better advance setup than a points distributor (and a late EI distributor would be correct for this engine with the correct curve and allow a larger amount of initial).
Good Luck,
PostPosted: Sun Oct 12, 2014 5:23 am
My 63 service manual shows .017-.023 gap 40-45 degrees dwell and 2 1/2 degrees btdc timing.
Brian
63 Plymouth Valiant Wagon
PostPosted: Sun Oct 12, 2014 1:10 pm
Thanks for all the sage advice! You guys are the best!
Users browsing this forum: Ahrefs [Bot] and 6 guests
