It is currently Wed May 27, 2026 2:31 am
 Post subject: Fuel Tank Replacement
PostPosted: Sun Oct 19, 2014 7:04 pm
Good Day,I am going to be replacing my fuel tank on a 72 scamp with the evap can. I am wanting to remove this item because it seems to be running a bit worse plus it smells like gas still even though I have plumbed everything in as best as possible.Plus the tank has a couple nice dings on the bottom and Im slowly replacing things with new. What tanks can I use that will eliminate having the can . Thanks for all the help/advice
PostPosted: Sun Oct 19, 2014 7:27 pm
Just run a vent line instead the evap line.....same tank.
I just did this on my DeSoto. I ran the line up to the top of the fender and put a vent cap on it.
PostPosted: Mon Oct 20, 2014 4:48 am
I need to replace the tank anyway I found a cut wire near the sending unit and also the dents while replacing the shocks. Theres two air lines in the trunk so I thought I had air shocke. They were very old rusty red no names with overload springs bolted to the shock. Where was the air going??
