It is currently Sat Dec 06, 2025 3:09 am
PostPosted: Sun Feb 08, 2004 3:26 pm
I would want to install connecting rods of slant6 198 on my 225 1980.is-this possible one? would I have enough clearance for. 565 lift.? I
look for rollers rockers. where do I can about it to buy? otherwise is
this I could install rollers rockers of ford (shaft mount)?
Thank-you!
PostPosted: Sun Feb 08, 2004 3:45 pm
The connecting rod's not gonna swap. The 198 is an earlier forged crank engine and the '80 is a cast crank. They changed in the mid '70's. The rods won't fit because the journal width's changed.
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Sun Feb 08, 2004 8:01 pm
For speed parts like roller rockers, call Cox Bros Fabrication. They are listed in the "network" section - 614-268-9920.
 Post subject: Roller rocker warning
PostPosted: Mon Feb 09, 2004 10:23 am
alot of people will tell you that the rollers are crap and need a oil spray bar while this is a good idea for positive oiling it is not really necessary for street aplications get a cox high vol oil pump and watch the gears every thousand miles for a while if after say 5 thousand miles all is still well its a good gear. Talk to the cox boys they are very knowledgable and will back their product
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
