It is currently Fri Jan 02, 2026 12:24 pm
PostPosted: Wed Sep 26, 2012 6:12 pm
hey everyone, i am just wondering if replacement checkball and weights are available anywhere for 1945 holley carbs? i took my carb apart to blow out the ports and lost the check ball and brass weight. Any suggestions would be great, thanks
PostPosted: Wed Sep 26, 2012 6:58 pm
They come in the rebuild kits. We have one local shop that carries them in Lynnwood, WA. Joe's Carb's. Great guys! They can be found in the vendor section.
Last edited by Aggressive Ted on Wed Sep 26, 2012 7:01 pm, edited 1 time in total.
PostPosted: Wed Sep 26, 2012 7:01 pm
the last one i got didnt come with the weight, do you know what brand kits come with both?
PostPosted: Wed Sep 26, 2012 7:34 pm
I just checked my kits down stairs and the last Hygrade and Wells kits that I bought had them. Those are fairly old kits...However, PM SL6Dan, I know he likes the Walker kits....and knows of carb shops in your area.
Last edited by Aggressive Ted on Wed Sep 26, 2012 7:35 pm, edited 1 time in total.
PostPosted: Wed Sep 26, 2012 7:35 pm
The weight doesn't come in a kit (anyone's kit) or as a separate repair part. Make your own from a short piece of appropriate-diameter brass rod from the hardware store. Size it to fit easily in the hole with some clearance around the sides.
PostPosted: Wed Sep 26, 2012 8:00 pm
ok, i wil order a kit tomorrow from the web and work on finding some brass rod. does anyone have a spec for the length?
PostPosted: Thu Oct 23, 2014 12:11 pm
I know this is an old post, but I found the answer to the accelerator check-ball weight question:
http://www.carburetor-parts.com/Holley-1940_ep_343.html
..."It is a hex shaped weight. I would say the most important spec is the weight. Too much weight and the check ball will not lift as it should.
Here are the specifications. Brass 1 gram in weight 7/16" long 5/32" wide, point to point of the hex.
An alternative is to add 1 more check ball on top of the 1st check ball."
I tried taking mine out while the carb is still mounted on the engine. Had to do some creative lifting with dental picks. Its brass so its not magnetic which is just so convenient <sarcasm>. I think I will try the 2nd ball trick (but I know that little 2nd ball isn't 1 gram in weight) or maybe a BB from the kids gun.
Users browsing this forum: Ahrefs [Bot] and 16 guests
