It is currently Fri Jan 02, 2026 5:29 pm
Post new topic  Reply to topic  [ 46 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: stud way
PostPosted: Fri Oct 24, 2014 11:56 pm
I would do the stud JB welded in, rather than JB weld and then drill and tap it. Agree with comment above, that is.
b
https://tinyurl.com/yynpj4v2
PostPosted: Sat Oct 25, 2014 1:28 am
I'm lazy. I would wrap a buttload of teflon tape around the bolt and tighten it down into the hole until it is snug. I have done that to stop manifold studs leaking in an emergency. I did this to the rearmost exhaust manifold stud on the slant in my brother's Dodge van and it held up for several years until I drilled the hole oversize and installed an oversize stud.
Given the low torque necessary for the valve cover, I think a teflon tape wrap would hold it tight enough to not leak until the new head is ready to go on.
PostPosted: Sat Oct 25, 2014 10:59 am
I'm going to do the stud - JB weld eventually, will find out how my carp repair went. I'm rather impatient and wanted to check for all leaks so wanted the valve cover sealed asap. A New York Minute is a long time for me. ;-) 5PM today the E. Valdez (my name for the truck) gets undocked and taken for a short cruise. Will report back upon return to dock.
Tom
'86 Alfa Romeo Spider, red "Dinsdale"
'10 Corvette, red "" (no name yet)
'95 Ferrari 348, red "Zoom"
'04 Maserati, black "Evil"
'05 Aston Martin DB9, green "Bond, Treasury bond."
'82 Dodge W150 Power Ram, yellow "E. Valdez"
PostPosted: Sat Oct 25, 2014 11:05 am
Many moons ago I heard this said: Why is it one has not the time to do a job correctly, but time to do it twice wrong?
PostPosted: Sat Oct 25, 2014 1:09 pm
You learn very little by doing it right the first time.....
PostPosted: Sat Oct 25, 2014 2:51 pm
Then obviously I am a smart man. :lol:
PostPosted: Sat Oct 25, 2014 3:35 pm
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
Lot of work with no heat tricky method:
Do you have room to drill & tap a larger hole so that a fatter bolt can be screwed in with red Loctite top ground off even with surrounded casting, and than a new proper sized drilled and tapped hole made to accept the correct valve bolt?
This is how I would be repairing it.
Richard (aka Fingers)
PostPosted: Sat Oct 25, 2014 7:55 pm
Woohoo! The valve cover does not leak any oil - was expecting a little dribble or drop - but nothing, nada, zip. Monday morning the car goes to the car was for an engine degreasing so the leaks can be identified. Did notice the cross-threaded oil pressure sensor is leaking a little. Most likely both the front and rear main seals are shot. Still had oil all over bottom of bell housing. No oil down sides of head as valve cover is holding. Rear axle front seal is leaking. Transfer case rear seal weeping a insignificant amount.
Got a quote of $450 for oil pan and front and rear main seals and damper/pulley assy. Think from years ago I was told there are other places on rear of engine to check for leaks that can also enter the bellhousing?
Yes, I'm always the one who says "if you're going to do it - do it right" but this "maybe good enough" was good enough.
Tom
PostPosted: Sat Oct 25, 2014 9:42 pm
Site Admin
There are other leak points as well, but since your having someone do your work, I won't interfere. Won't mention the alternator bracket to block bolt or anything like that.
Shoot, I can seal a slant for five bucks, but then I do all my own install and assembly.
CJ
PostPosted: Sat Oct 25, 2014 10:55 pm
CJ
Feel free to interfere ;-)
I' normally take the time to do learn and the work myself but am in a position where I want to get this critter on the road and out of the garage ASAP - hence the rush with the valve cover bolt.
Tom
PostPosted: Sun Oct 26, 2014 5:36 am
Site Admin
Sorry 'bout that. I'll get out of my box every once in a while, and you didn't deserve that.
Take a look at the alternator mounting point. It'll make a mess.
CJ
PostPosted: Sun Oct 26, 2014 6:53 am
What/how does it leak there?
--> The Diesel Corvette <--
PostPosted: Sun Oct 26, 2014 7:52 am
Site Admin
The front bolt that holds the Alternator bracket to the engine block goes into the lifter area, so can leak oil. It's actually a fairly common leak point, and presents like oil leaking from the valve cover on the passenger side.
A dab if RTV on the bolt threads will solve it.
CJ
PostPosted: Sun Oct 26, 2014 8:37 am
Cool, thanks.
PostPosted: Sun Oct 26, 2014 8:38 am
CJ
Thanks for the heads up. Maybe that's what caused the valve cover bolt near there to get stripped - maybe there is a leak at that bolt. Will clean it up and inspect.
Tom
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 19 guests
