It is currently Mon May 25, 2026 12:43 am
 Post subject: K frame ID
PostPosted: Mon Nov 17, 2014 6:20 pm
picked up this K frame some time ago
I am not an expert here, but I think there are:
72 and prior K Frames
73 and after K Frames
maybe early A K frames ?
V8 and slant six K Frames
anyone want to take a shot at this one, and how does one know the difference?
https://www.flickr.com/photos/13718356@ ... 336462122/
thanks
 Post subject: The break down...
PostPosted: Mon Nov 17, 2014 7:03 pm
You are correct in the breakdown on the K-members...for the mid to late A-body:
1963-1966 A-body
/6 and LA V-8
1967-1972 A-body (uses 'sandwich' motor mounts)
1967 only had a single mounting point at top for the idler arm,
and you have to use the 1967 specific arm, the 1968-1972 K,
uses the "through" bolt version you have (you could also
remedy the 1967 K with a bit of welding skill and metal to
get the more common 1968+ idler to fit.
/6 and LA V-8
1973-1976 A-body with spool/cradle mounts
/6 and LA V-8
There also was a MP Big Block V-8 K available for the late A-bodies.
Just off hand yours looks like a 1968-1972, but I can't tell from the perches (angle of the photos?) if it's a V-8 or /6.
PostPosted: Tue Nov 18, 2014 8:24 pm
I'm not an expert on the V-8 cars either, but I'm "leaning" towards that being a 68-72 slant K-frame. I see the engine mount brackets are very non-symmetrical, with the right side almost at the frame rail mounting points.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Wed Nov 19, 2014 4:43 am
thanks guys,,
always good info available on this forum :)
PostPosted: Mon Nov 24, 2014 4:11 pm
The '73 and up K frames had the through-the-frame sway bars, which this one looks like it has. However, it also looks like it has the sandwich type mounts, so that would require a '72 and before nod. The 68-72 K members I have seen are solid on the bottom. It is a bit confusing as a result.
I wonder if there was a late 72 K frame that had the later sway bar set up, but the earlier sandwich type mounts. And I agree with the fact that the driver's side mount is higher than the pass side. That would require a slant six vote.
Sam
