It is currently Mon Jun 22, 2026 6:07 pm
 Post subject: Oil pump issue?
PostPosted: Sat Dec 06, 2014 1:43 pm
Has anyone ever seen this before? I was installing the Dutra oil pump in my "race" truck and needed to replace the gasket on the pressure relief nut. So I pulled a new pump off the shelf and robbed the gasket. But while I was looking at it I noticed quite a restricted passage on the new pump. Here is the picture of one of Doug's modified pumps and the restricted one. I would say it was an awful casting for sure. I will have to get out my die grinder and do some serious work on it if I ever want to use it.
Rick
 Post subject: Re: Oil pump issue?
PostPosted: Sat Dec 06, 2014 1:47 pm
Rick
That's why you keep using old ma mopar's pumps.. With a better flowing AL casting you can relieve some of the restriction with your die grinder on an old original one.
That cast iron Piece is too heavy anyway :-)
PostPosted: Sat Dec 06, 2014 3:16 pm
I don't care how much it weighs, but it has a 75% smaller hole than it should! :lol: :lol:
PostPosted: Wed Dec 31, 2014 6:25 am
This is one example showing why I got into porting and "blueprinting" SL6 oil pumps...
The aftermartket pump housing casting quality is "all over the map".
