It is currently Sat May 16, 2026 4:28 pm
PostPosted: Sat Dec 06, 2014 4:54 pm
Been noticing it lately but not sure what it is. I used a big screwdriver to kind of listen around and I can sort of hear it when I place the screwdriver on the head next to the valve cover but it sounds much louder when you're just standing by the car listening. Doesn't go away when I apply throttle either. Anyone know what it might be?
http://vid48.photobucket.com/albums/f20 ... d2zueq.mp4
PostPosted: Sat Dec 06, 2014 5:30 pm
Contributor
Sounds like a lifter...if your engine has hydraulic lifters.
PostPosted: Sat Dec 06, 2014 5:35 pm
It's mechanical. Basically stock other than the HEI ignition and Super Six setup.
PostPosted: Sat Dec 06, 2014 5:36 pm
Due to the nature of the sound, I would be looking at an exhaust manifold leak. Then check with a long screwdriver down on the fuel pump.
PostPosted: Sun Dec 07, 2014 3:27 am
Contributor
Since you have mechanical lifters, I agree with this diagnosis. Use a rubber tube to listen and follow the gaskets around the manifold. A leak should be easy to find.
PostPosted: Fri Jan 09, 2015 8:10 pm
this may seem a bit easy, but I had a similar ticking sound, spent ages trying to find the source, then one day I removed the oil dipstick with the engine running (forgot why)and the sound disappeared, put it back in and it re appeared...I twisted the dip stick 30 degrees counter-clockwise and the ticking went away...put it back and it reappeared. I have a 1973 Dodge Dart sport 225, no modifications yet..its cheap and easy to try it.
PostPosted: Sat Jan 10, 2015 6:06 am
If lifter or rocker or exhaust is not it, try check down at the fuel pump with a long tube or screwdriver. They can be noisy at times, and this sounds pretty similar to that.
PostPosted: Thu Feb 19, 2015 2:11 pm
Thanks for the help guys. I tested it for an exhaust leak and came up with nada. So I adjusted the valves and once I got to one of the exhaust valves, I turned the adjuster screw to tighten it ever so slightly and the noise completely went away. I figured one of the valves was going to be really loose but it just took about 1/16th of a turn and she purrs like a kitten now.
 Post subject: i have the same sound
PostPosted: Tue Mar 17, 2015 8:01 pm
What do you mean by adjusted the values?
PostPosted: Tue Mar 17, 2015 8:03 pm
What do you mean by adjusted the values? How did you do that exactly step by step?
PostPosted: Tue Mar 17, 2015 8:26 pm
if you are new to the slant the FAQ section is your friend.
http://www.slantsix.org/forum/viewtopic ... ght=#72139
PostPosted: Tue Mar 17, 2015 8:31 pm
Please read the link Junior gave you inthe previous comment. I also gave you a link to a Youtube video showing the process in a different thread.
/6 Dodge Charger 69
Image...there's nothing like using the "Search" link above to solve most of your problems...
