It is currently Wed Oct 14, 2026 4:50 am
PostPosted: Tue Dec 16, 2014 11:33 pm
can someone please help identify what year this block is? or any other information?
70 Plymouth Valiant 4dr
PostPosted: Wed Dec 17, 2014 4:45 am
It's a 225 must be a cast crank block appears to be made the 30th week of 1985.
Brian
63 Plymouth Valiant Wagon
PostPosted: Wed Dec 17, 2014 5:04 am
The 1st photo is too far right to catch the full engine casting number, unless someone can tell it from the '030' which should be the last 3 digits of a 7 digit number.
It is a later block due to the core plugs arrangement in the 1st photo. (Dunno what year that changed; someone here certainly does.)
PostPosted: Wed Dec 17, 2014 6:27 am
I had no idea they made them up until 85.
PostPosted: Wed Dec 17, 2014 6:35 am
1987 in trucks was replaced for 1988 with the 3.9 V6.
Brian
PostPosted: Wed Dec 17, 2014 10:38 pm
6: 1986 model year
225: Engine displacement
K: Toluca (Mexico) engine plant
2: Production line at factory
1111: Engine built on 11 November, 1985
PostPosted: Wed Dec 17, 2014 10:57 pm
Obviously, that block goes to 11. :lol:
PostPosted: Thu Dec 18, 2014 8:21 am
Were gonna see. Im working for a guy who did alot of hemi racing in the 60s. I pick his brain daily.
Im just hoping I dont get stuck in the pod :lol:
PostPosted: Tue Feb 24, 2015 8:22 pm
Took the block apart and date on the bearings is october 1975? Forged crank cause I bought cast crank bearings and they were too small :shock:
 Post subject: Lol...
PostPosted: Tue Feb 24, 2015 8:50 pm
Is that "K" really an "R"?
Sounds like you have a 1976 model year engine?
PostPosted: Wed Feb 25, 2015 12:26 am
Does that make this block louder than the other geezers? :lol:
PostPosted: Sat Sep 19, 2015 3:12 pm
I also have the 030-13 but no numbers before the "030" , the small plate to right of that number ( closer to firewall) is "1066". also i didnt see any numbers on the lip under the head cover...unless i need to remove the cover. is this a 66 engine? this is in my' 77 d100. TYVM y'all.
thanks all!
PostPosted: Sat Sep 19, 2015 3:36 pm
I also have the 030-13 but no numbers before the "030" , the small plate to right of that number ( closer to firewall) is "1066". is this a 66 engine? this is in my' 77 d100. TYVM y'all
No, it is not a '66 engine.
PostPosted: Sat Sep 19, 2015 3:55 pm
there are no numbers on the deck lip near the plugs where there should be-
the engine was also rebuilt perhaps the numbers on the deck lip were ground away? if so, is it possible to know year manufactured some other way?
thanks again
thanks all!
PostPosted: Sat Sep 19, 2015 5:05 pm
dummy check: pic of the area where it seems numbers should be stamped.
thanks all!
