It is currently Sun Jun 21, 2026 1:21 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
 Post subject: Lol...
PostPosted: Sun Dec 21, 2014 11:48 am
Ah just pull it out the bottom.
Done it that way too...takes longer getting it all out, but you can recondition the steering components and put it all back in at once...LOL
PostPosted: Mon Dec 22, 2014 12:48 am
Patrick made a dolly for doing just that. It supports the K frame and trans crossmember. Engine and trans come out in one piece.
PostPosted: Mon Dec 22, 2014 9:18 am
Car Model: '64 Valiant Convertible
Before loosening the 4 hood mounting bolts, I drilled two 1/8 inch holes through the hood mounting bracket and hood (in an inconspicuous location) on each side.
Then during hood installation, I just shoved some drill bits into the holes as alignment keys and tightened the bolts. Perfect hood alignment (well... as good as it was when I started).
Whatever tricks you use, It will be worth having the hood out of your way.
