It is currently Wed Jun 03, 2026 6:47 pm
PostPosted: Sun Dec 28, 2014 10:14 am
Car Model: '64 Valiant Convertible
Greetings.
Can anyone post a pic or accurately describe proper lift technique for engine/trans lift from a Valiant?
Does manifold combo need be removed? does this help/hinder due to balance concerns?
Thanks for your expertise.
PostPosted: Sun Dec 28, 2014 1:25 pm
Right beside the valve cover...in the middle of the head....are two threaded 3/8 bolt holes. Bolt a short length of chain between them .
PostPosted: Sun Dec 28, 2014 3:13 pm
What he said ^^, just did this a couple weekends ago. Very easy and pulled it with a tractor. Not with the trans attached but with a leveler it might help.
PostPosted: Sun Dec 28, 2014 4:22 pm
You can keep the manifolds on. 2" long 3/8" bolts coarse threaded with flat washers to spread the load on the links; grade 5 or grade 8, not ungraded. Have extra links in the chain length between the 2 bolts so you can adjust the point at which the hook attaches for balance; it also lowers the chain tension and side force on the bolts to have the extra links.
A couple of pix here: http://www.forabodiesonly.com/mopar/sho ... p?t=300385
Trannie removed makes it easier IMO but you can do it with it attached; you can set the hook along the chain for the best angle.
PostPosted: Sun Dec 28, 2014 5:00 pm
Thanks very much to all of you.
Happy new year!!!
PostPosted: Sun Dec 28, 2014 8:31 pm
6 Pack Dart
Copy from the other web site---
"Senior Member
Just did this a month or so ago. Like the other guys have said. 2 bolts sitting on top. Front one lifts and balances engine only. Back one balances engine and transmission together. Both work for almost perfect balancing."
Richard
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], casedawg and 2 guests
