It is currently Mon May 25, 2026 12:31 pm
PostPosted: Mon Dec 29, 2014 1:31 pm
the shift shaft is leaking where it enters case.....where do I get a new seal???? how do I replace it????
PostPosted: Mon Dec 29, 2014 1:48 pm
You can pry the old one out with a pick or other small pointy object. New shifter shaft seals are available wherever trans parts are sold. I.E. http://www.makcotransmissionparts.com
Throttle lever seal
Shift linkage seal
PostPosted: Mon Dec 29, 2014 11:10 pm
It can be done with the valve body in place, but it is a whole lt easier with it out, especially if the trans is still in the vehicle. :D
PostPosted: Thu Jan 01, 2015 8:19 am
found the parts ...waiting for them to get here....and a warm day to install
