It is currently Mon Dec 02, 2024 4:38 pm
PostPosted: Wed May 21, 2014 7:49 am
Hi all:
Based on what I've read here, I'm under the impression that (at least some) model numbers for the Holly 1920 "Economaster" carb are:
7585
7586
7587
Are there others additional to these?
Thanks.
PostPosted: Thu May 22, 2014 4:21 pm
PostPosted: Fri May 23, 2014 8:21 am
<nod>
Addigng 7584 to the watch list. Thanks!
PostPosted: Mon Jan 05, 2015 6:10 am
Do any of those work on the early A's with the mechanical rod linkage?
PostPosted: Mon Jan 12, 2015 8:20 pm
Well it looks like they did make such a critter:
Unless that atomizer is swapped in from a different carb if that's possible.
(Not mine, random picture from the web.)
 Post subject: No, but...
PostPosted: Mon Jan 12, 2015 8:29 pm
No, but on the Holley's you can unbolt the rod bail and bushing for the rod linkage from the throttle lever and install on another Holley 1920.
 Post subject: Re: No, but...
PostPosted: Mon Jan 12, 2015 8:47 pm
I wonder if that's what they did or if that's OEM we're seeing in that picture?
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 15 guests
