It is currently Mon Nov 23, 2026 12:12 pm
 Post subject: '62 power steering
PostPosted: Tue Jan 06, 2015 5:54 am
Car Model: 1962 Plymouth Valiant
Will a power steering pump, resovoir, and steering gear box out of a '65 Valiant fit into my '62? Only part listings I've found say '65 and up. Nothing for my '62. Thanks in advance,
PostPosted: Tue Jan 06, 2015 10:18 am
If it is a Chrysler power steering gear that is bolted to the K-Frame then yes, 62 thru 66 parts should all work.
PostPosted: Tue Jan 06, 2015 11:40 am
Car Model: Road Runner
Converted the wifes 62 from manual to power a while back. Hardest part to find were the Saginaw pump brackets for the /6. If I wanted to spend a lot of time and make it really spiffy I'd convert the K frame to a double shear (later) Idler arm to allow quick ratio arms.
Really easy swap, just be mindful of the column swap/modification if you didn't already know about that. Hers was a PB904 car, so I used a Flaming River adapter for a clean and easy install.
PostPosted: Tue Jan 06, 2015 3:42 pm
Thank you guys so much. I already have power steering in my '62, it's just leaking and this guy is offering me his new (probably remanufactured) steering gear box and pump for $65.00. Seemed like a good deal if I could swap them out easy enough.
