It is currently Wed May 27, 2026 5:21 am
PostPosted: Tue Jan 06, 2015 7:06 am
Car Model: 1966 2D Dart
I am installing a 22" wide Griffin for my slant. The upper hose was a pain with fuel rail hosing with original radiator. With Griffin I will need 3 pcs 90 angle hoses to build the upper hose.
If an alternative thermostat cover with outlet to the left will be available the hosing will become much better.
Has there been such covers?
If yes where I could get one?
PostPosted: Tue Jan 06, 2015 7:16 am
There is a straight cover available, I did the same thing anew years back. I don't remember what it was for but the guys at my local auto parts store pulled it off the shelf for me, common item. Also if you measure the lengthens and where the curves need to be you can find a hose that will work in one piece, again I got a hose for mine but don't remember what it fit. I do know it was off a truck and had at least one to many turns that I cut off to make a nice custom fit. For the bottom the stock hose worked, I had a friend relocate the connection on the radiator a little lower. Hope I am of some help.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Tue Jan 06, 2015 9:56 am
Late 318 with the small thermostat should do the trick. :D
PostPosted: Tue Jan 06, 2015 5:21 pm
If you want cast aluminum and don't mind non-Mopar stuff, I once used a Ford Taurus 3.8 housing, like a Four Seasons #84999.
Probably fits more applications, should be boneyard friendly.
Just had to drill the holes oversize.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Tue Jan 06, 2015 5:29 pm
I have the housing and the hose that works well listed in my Valiant build thread over in the Virtual drag strip section. Part #'s are there too. I will try and get you a link.
Rick
Here is the thread. If you have the 1 3/4" angled lower outlet it also shows what hose works for that as well. hope it helps.
http://slantsix.org/forum/viewtopic.php ... ose#383413
PostPosted: Thu Jan 08, 2015 3:27 am
Thanks once again. I will check the part out from local US cars part store. If not available, then rockauto.com
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 12 guests
