It is currently Wed Nov 25, 2026 2:42 pm
 Post subject: Rods 198 and 225
PostPosted: Sun Feb 15, 2004 6:58 am
Hello, what is the size of 198 and 225 rods journal ?
Thanks
PostPosted: Sun Feb 15, 2004 9:35 am
The crank "pin" is 2.187 in standard from. undersize of .010, .020 and .030 are common but I have also seen .040 and .060 undersize bearing inserts.
This applies to 170, 198 & 225 Slants
http://www.slantsix.org/articles/stroking/stroking.htm
PostPosted: Sun Feb 15, 2004 10:49 am
I have a 1980 crank, why i can't put a 198 rod in this crank?
I read is not interchange. WHY??
Thanks
 Post subject: Jornal width
PostPosted: Sun Feb 15, 2004 11:35 am
a 1980 crank will be cast. 198 rods were for forged crankes. Cast & forged cranks have different rod journal widths.
Cheers!
Al T
 Post subject: Re: Jornal width
PostPosted: Sun Feb 15, 2004 9:52 pm
The good news is that the forged con rod is wider.
With some special machine work, 198 rods could be machined to fit on the cast crank. (for less money and fuss you could find a forged crank SL6 to build)
PostPosted: Mon Sep 25, 2006 10:17 am
I decided to dig up this old thread and ask the original question again since I can't find the answer. What is the big end width of a cast crank 225 connecting rod?
Users browsing this forum: Amazon [Bot], Google [Bot] and 7 guests
