It is currently Sun Nov 15, 2026 5:52 pm
PostPosted: Sat Jan 24, 2015 7:16 am
our 1983dodge ram 100 has a factory 727, I found the invoice from dodge to the dealership in the glove box, it has all the options including the 727 transmission listed, it also has a aluminum ring (flat like) washer taped to it with some numbers stamped on it...what that anywho?
slant six's RULE!
http://www.usajon.com
PostPosted: Sat Jan 24, 2015 7:52 am
I don't have numbers for you, but in my almost 20 years of playing with slants I have only ever had my hands or eyes on TWO slant six specific 727. They are out there, but they are uncommon.
PostPosted: Sat Jan 24, 2015 7:53 am
That aluminum ring with numbers is your key code for the door and ignition locks.
Brian
63 Plymouth Valiant Wagon
PostPosted: Sat Jan 24, 2015 8:03 am
Actually, I have seen quite a few, in "fleet" (EI: police/taxi/etc) vehicles.
Friend of mine took a slant 727 to the recycler because he couldn't sell it.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Sat Jan 24, 2015 8:41 am
thanks guys. just hauled some heavy cut firewood and the truck preformed great. even though the rear was low to the ground.
http://slantsix.org/forum/viewtopic.php?p=420257#420257
slant six's RULE!
PostPosted: Sat Jan 24, 2015 11:52 am
Brian
Am I missing something here? or does this actually have some relevance to the slant 6 727 Discussion?
PostPosted: Sat Jan 24, 2015 12:10 pm
Brian
I was simply letting him know that tag was most likely his key code for the truck.
Brian
PostPosted: Sun Jan 25, 2015 3:04 am
I'm a noob with my first slant six in my '86 Ram 150 Royale SE--it has an automatic in it--what do I have? What is the more common automatic?
Where would I look to determine what trans I have?
PostPosted: Sun Jan 25, 2015 5:36 am
Car Model: '23 T-bucket
Biggy; You could try here; http://www.mymopar.com/downloads/transguide.pdf
The shape of the trans pan will tell you.
Roger
PostPosted: Sun Jan 25, 2015 8:37 am
Even on this side if the pond, I have the impression that a great number of vans and trucks came with a 727 behind the SL6. It may have to do with local vehicle weight classifications.
I recently switched my 727 for a 904LA plus an extra converter. A 727 is noticeably heavier than a 904.
Olaf
Aspenized
PostPosted: Sun Jan 25, 2015 9:38 am
I've had a few of them, both standard and lockup. I sold 1, the rest I had to give away.
Yeah, the aluminum disc with the paperwork sounds like the key numbers to me also.
