It is currently Sat May 02, 2026 5:13 am
 Post subject: oil pump gear
PostPosted: Mon Jan 26, 2015 8:05 am
Some have suggested getting an OEM cam used and doing a regrind, particularly using the oil pump gear that was mated to the cam in the original engine. Sounds like a good idea.
Q: I have DD oil pump, can I swap out the gear itself, or do I have to swap out the whole shaft plus gear? I understand there are many designs of impellers on these pumps, so how do I swap out the gear?
Are there no good aftermarket cams out there?, what about comp cams or other name brands, are they all junk?
thanks all,
Brian
https://tinyurl.com/yynpj4v2
