It is currently Wed May 06, 2026 2:13 pm
PostPosted: Wed Jan 28, 2015 10:32 am
Hey guys,
I've heard that you have to use headers with a Clifford Intake manifold. Is this due to the lack of heat riser provision? Or is the intake runners fatter, taking up room?
Basically what I'm getting at is, can I run a Clifford Intake with dual dutra duals?
Thanks,
Aspen76
76 Dodge Aspen
225 Super Six w/ Dutra True Dual Exhaust
http://i1245.photobucket.com/albums/gg5 ... AG0095.jpg
http://www.youtube.com/user/BZuko1?feature=guide
PostPosted: Wed Jan 28, 2015 11:06 am
Yes you can, I do. Two dutra castings will work. A single dutra up front and modified stock in rear will not.
The clifford has no provisions for those three bolts tieing the intake to exhaust. Also the clifford has a water passage underneath that sticks out an inch or so stretching front to back. Infact I had to grind that passage and/or part of the dutra pipe flange to make it fit without interference.
PostPosted: Wed Jan 28, 2015 11:56 am
Online
You dont have too.
Cliffords have no exhaust heat provision.
I have used clifford intakes with Mopar Performance headers. (massaging on #6 Runner Required), and Hooker super comps, and Dutra duals.
They are fatter then stock or offenhasuer Manifolds with a slightly different runner path,
The clifford manifolds probably work well together as a matched set without much fuss as they were designed to work that way, but others can work with some adjustments.
PostPosted: Wed Jan 28, 2015 1:11 pm
Many Cliffords intakes do not have this. I wish mine did! :lol: :lol:
Rick
PostPosted: Wed Jan 28, 2015 1:38 pm
Online
Rick
I think that is a bolt on option that can be added.
PostPosted: Wed Jan 28, 2015 6:17 pm
All the water heater ones I saw were molded right in to the base.
Rick
PostPosted: Wed Jan 28, 2015 10:39 pm
Their earlier manifolds (without the -wh at end of part number) didn't have them cast in. Their later and current manifold does.
This is for the 4bbl. I do remember someone bolting a hot water plenum to the bottom side. It may have been a custom drilled non -wh manifold or possibly not a 4bbl all together.
PostPosted: Thu Jan 29, 2015 2:57 am
I had a Clifford heater that went between the carb adapter and carb. Not sure who ended up with it, probably someone on the board. :D
PostPosted: Thu Jan 29, 2015 4:19 am
Clifford has had several variations of their 4 bbl ("normal") manifold. Biggest problem is having the same part number for all of them except the 4500WH which has the cast in water manifold on the bottom.
PostPosted: Thu Jan 29, 2015 4:52 am
Perfect, Thanks yall!
Aspen76
76 Dodge Aspen
PostPosted: Thu Jan 29, 2015 1:24 pm
Homemade under carburetor hotspot mounted on Clifford 4 barrel intake.
