It is currently Sat May 23, 2026 9:18 pm
 Post subject: Identify block
PostPosted: Sat Jan 31, 2015 6:43 am
I have a block with the following info, what does it mean? : On deck- 8 W 225 6076, on the driver side- 530-7, 0468.
71 Dart /6 2bbl, 72 Dart 360- 11.10 @117
 Post subject: Re: Identify block
PostPosted: Sat Jan 31, 2015 11:34 am
8: Engine built for a 1978-model vehicle.
W: Engine built at Windsor Engine Plant
225: Cubic inch displacement
6076: Engine built on 17 March 1978
PostPosted: Sat Jan 31, 2015 1:06 pm
Thank you!
PostPosted: Sun Feb 01, 2015 5:58 am
Dan, can you explain how this is determined, so even I can understand it?
PostPosted: Sun Feb 01, 2015 10:25 am
First you eat a lot of cereal and save the boxtops. Then you send them off, together with $1.70 postage and handling, and wait eight to ten weeks. Then your secret decoder ring comes in the mail. Some assembly required, batteries not included. Once your parents put it together, you put it on and shift it into "date code" mode, then apply it directly to your forehead, and then those date codes read out as calendar dates! Simple.
Actually, these date codes are days on a 10,000-day calendar wherein day (0000)1 is 29 July 1961. They count up from there. I have an Excel spreadsheet that lets you put in the date code and it spits out the calendar date. There's a web version here. Note you have to do a reality check on the result, because sometimes a 4-digit date code is simply a regular day and month (such as "1024" meaning 10/24, that is 24 October.
PostPosted: Sun Feb 01, 2015 6:15 pm
Thanks, Dan
