It is currently Fri May 22, 2026 9:15 am
PostPosted: Sun Feb 01, 2015 5:52 pm
what's a good replacement aluminum/steel ?
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Feb 01, 2015 6:13 pm
"what's a good replacement aluminum/steel ?"
one that doesnot leak
PostPosted: Sun Feb 01, 2015 6:42 pm
These days... you would be lucky to find a cast iron housing water pump.
A die cast alm. GMB pump, with the 8 fin impeller, is a common one we see today and those work well..
PostPosted: Sun Feb 01, 2015 7:23 pm
Doug, is there any way to be sure and get the 8 fin impeller? I ordered the same part number at Advance 2 times and got one 8 fin and one 6 fin one.
Rick
PostPosted: Mon Feb 02, 2015 2:16 am
I have a spare used one that does not leak.....
it's a 6 blade genuine Chrysler mid 1970's.
slant six's RULE!
PostPosted: Mon Feb 02, 2015 8:26 am
I also keep all my cast iron SL6 WP "cores"... and also re-use any good ones.
Someday... I may find a way to rebuild the others.
As for getting an 8 fin Al. WP, I just order and then look at the pump when it arrives. I tell the counter person to get me another, if I do not get an 8 fin.
Users browsing this forum: Google [Bot] and 14 guests
