It is currently Sun Jun 14, 2026 3:09 pm
PostPosted: Sat Feb 07, 2015 1:27 pm
I'm going to rebuild my slant 6 (76 225 in a volare) and I want to replace the original 1 bbl with either a single 4 bbl or ordering from Clifford the dual Weber carb kit with headers. Any feedback will be appreciated.
My volare has a 225 slant 6. Just got it and gonna give some love and restore it!
PostPosted: Sat Feb 07, 2015 1:56 pm
Welcome to the Forum.
What is your plan for the rebuild stock or otherwise?
 Post subject: dual Webers
PostPosted: Sun Feb 08, 2015 8:18 am
You might want to try dual 2bbl 32/34 DFT Webers (for 1.8 or 1.9L Ford Escort) from Tom Langdon, $90 a piece new, and an Offenhauser dual carb intake milled for the Webers. With the linkage kit, a Lokar kickdown cable, fuel pressure regulator and some custom (but simple) fabrication you can build your own for ~$500. The Clifford set up is $1700.
One note, I eventually built a heat shield as heat was an issue for me. I have the dimensions for the heat shield as well.
See this thread: http://slantsix.org/forum/viewtopic.php ... n&start=15
I'd be happy to share my experiences with this setup, runs great.
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Sun Feb 08, 2015 6:16 pm
Be very careful before you decide to spend any money with Clifford. They have a long and ugly reputation for being a bunch of clowns; see for example here, here, here, here, and here. Much of what they sell is inaccurately described, and a lot of it is not even slightly cost-effective. The good news is that you don't need to go to Clifford to get hot rod parts for slant-6s; there are lots of other, better options. See for example Dutra Duals and header options discussed in this thread and this one, Erson custom cams, HEI ignition upgrade, Mike Jeffreys windage trays, Hurricane intakes, other exotic intakes. Hi-perf engine buildup here, high-perf parts and build info here.
 Post subject: SL6 Forum
PostPosted: Sun Feb 08, 2015 7:17 pm
SlantSixDan is one of the guru's of this site. You can't go wrong taking his advice. The guys on this board have been building/driving/racing/living SL6's for decades. If he says be wary of Clifford, I would heed his advice....
brian
PostPosted: Mon Feb 09, 2015 8:48 pm
Thanks guys for the info. I like the way the 2 carb setup looks. I'm trying to make this car practical for driving along with something thats not seen around to often at the local car shows. I really don't want to spend the money on a clifford setup but would you recommend 2 1bbl carbs or 2 2bbl carbs?
PostPosted: Mon Feb 09, 2015 10:04 pm
One 2bbl. Which one to run depends on how much zip you want. You could swap on a factory "Super Six" setup, those work well. Or you could do a bit of extra work and swap on a Motorcraft 2100, those work really well. And I'm not just saying that because I have a custom aluminum intake manifold and brand-new 2100 carb where I'd rather have shelf space, because I also have a bunch of Super Six intakes and at least one complete kickdown setup where I'd rather have shelf space. :lol: :shock:
PostPosted: Tue Feb 10, 2015 5:23 pm
Make sure the 2 x 2bbl will fit! My truck will require me to put in a newer offset wiper motor when I finally get the 2x 2bbl Carter/Webers worked out- you may be getting near the firewall or brake booster or such with a car. Check the fitup of the intake manifold to the exhaust manifold - the runners where they meet the head have to be on the same plane with room to move back and forth a tiny bit. Snug everything up and check for fit - right down to the carb. Better to find out you have fitup problems now - you may not see then when you install the parts to the engine.
Tom
'86 Alfa Romeo Spider, red "Dinsdale"
'10 Corvette, red "" (no name yet)
'95 Ferrari 348, red "Zoom"
'04 Maserati, black "Evil"
'05 Aston Martin DB9, green "Bond, Treasury bond."
'82 Dodge W150 Power Ram, yellow "E. Valdez"
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 13 guests
