It is currently Fri May 22, 2026 11:27 pm
PostPosted: Thu Feb 05, 2015 5:55 am
Car Model: 1964 Dart 270
On a 1964 Dart GT, what size socket is used to remove upper ball joint?
Thanks Steven
PostPosted: Wed Feb 11, 2015 9:25 pm
Hi 64DartGT, here are some old threads on the subject:
http://www.slantsix.org/forum/viewtopic.php?p=408189
http://www.slantsix.org/forum/viewtopic.php?t=48791
If you search for 'ball joint socket', you'll probably find many more!
Olaf
Aspenized
PostPosted: Wed Feb 11, 2015 9:52 pm
Thanks Olaf! Searched but had trouble identifing socket size? From reading my car being a 1964 it has the small ball joint in the UCA, which means it takes a small ball joint socket to back it out?
PostPosted: Wed Feb 11, 2015 10:13 pm
Mopar used two Mopar upper ball joint specific sockets over the years. The larger size was for trucks, vans, and larger cars, the smaller size was for smaller cars. These are not cheap. The last one I bought was $25 for the single socket. Ask around local old-time shops or car enthusiasts. You may find someone with these odd large square sockets with rounded corners.
PostPosted: Wed Feb 11, 2015 10:35 pm
Thanks Reed will do! :-)
PostPosted: Thu Feb 12, 2015 3:19 am
Get a 1 3/4 3/4 drive socket and grind out 4 points of the 12 and it will fit the ball joint.[/img]
63 Plymouth Valiant Wagon
PostPosted: Thu Feb 12, 2015 10:42 am
Thanks bcscheif!
PostPosted: Thu Feb 12, 2015 12:06 pm
FYI:
The big one is 2 1/8, the small one is 1 7/8. I am not sure rounding the corners off of a 12 point socket will get you where you need to go.
PostPosted: Thu Feb 12, 2015 1:02 pm
I usually measure those ball joints with a very large pipe wrench...........
PostPosted: Thu Feb 12, 2015 6:54 pm
Thank you Reed! A picture is worth a thousand words? This picture will help many other members who want change out there ball joint, 1 7/8 is it! :D
PostPosted: Thu Feb 12, 2015 6:59 pm
Sandy is on the right track with the pipe wrench. It works fine for removal. However, I would like him to share how he measure the torque on the ball joint with the pipe wrench when he installs the new ones.
PostPosted: Thu Feb 12, 2015 7:04 pm
That's funny Reed, you have a good idea for a new tool, torque pipe wrench to torque everything to spec. :)
 Post subject: Lol...
PostPosted: Thu Feb 12, 2015 8:09 pm
The torque spec on the large/late A-body ball joint is 175+ ft/lbs "minimum"...a pipe wrench and a 6 ft pipe of pie on the handle and some good leverage should meet the minimum torque spec...
:lol:
PostPosted: Thu Feb 12, 2015 8:18 pm
Definitely have to have a cheater bar on that one!
PostPosted: Fri Feb 13, 2015 3:12 am
I don't think I have a pie pipe! :lol: :lol: :lol: :lol:
Users browsing this forum: Amazon [Bot], Google [Bot] and 9 guests
