It is currently Sun May 03, 2026 5:49 pm
PostPosted: Mon Feb 16, 2004 12:00 pm
i'm looking for a torque converter in the 2500 rpm range that will fit our 904. I'm having very little luck finding a converter period, much less one of a decent stahl speed, much less for a decent price.....please help! :oops:
PostPosted: Mon Feb 16, 2004 12:59 pm
It sounds like you are working with a 67 and older "small hub" unit.
What year is the car & engine?
PostPosted: Mon Feb 16, 2004 5:50 pm
Call Andre, at Edge Racing converters.
http://www.edgeracingconverters.com/index.htm
He built the converter I run in my Cuda. I ordered it on Monday morning, and had it on Wed afternoon, overnight air. 3000 rpm stall, early small crank pilot, late large input shaft.
Tell him Charlie Schmid from Florida recommended him.
PostPosted: Mon Feb 16, 2004 8:53 pm
If you are out West, you may want to try Continential Converters.
Another supplier in the Midwest is... Midwest Converters.
PostPosted: Tue Feb 17, 2004 12:06 pm
I was having the same trouble of not finding any. The guy who did my tranny work was able to call a factory that he order his stuff from and managed to have them custom make one for me. I dont know if this is the best price option to go with but if all else fails give it a whirl!
PostPosted: Tue Feb 17, 2004 3:17 pm
Doc, how much was it from Continental?
-Jesse
PostPosted: Tue Feb 17, 2004 7:25 pm
-Jesse
The converter i got form Continential is a "special order" 8 inch unit, it was kind of "spendy" at $700.00 but it works real good.
I'm sure they have cheaper ones to fit your need so give them a call and get a quote.
PostPosted: Wed Feb 18, 2004 9:58 am
this si not a small hub setup. I am putting the 225 from a 71 dart into my 74 duster.
PostPosted: Wed Feb 18, 2004 10:37 am
I don't know why you are having a problem finding a converter. Get in touch with any of the converter manufactures listed. They should be able to help you. Just mke sure you till them it is for a slant six, or you will not get enough stall speed.
PostPosted: Thu Feb 19, 2004 11:17 am
Like Charlie said, with the later engine you can easily find a converter. Midwest is one of the least expensive I've found, and I know others on this board have used them.
Joe
PostPosted: Sun Mar 14, 2004 2:13 pm
I got in contact with a guy named marshall from www.campbellenterprises.com and they can make you a custom converter as a very decent price and following your specs. I asked for a 11" 904 converter, 2300 rpm stall, and the budget was cheap: 250 bux. plus shipping, of course. they have special HD flex plates (matching their special converters) at less than 40, special HD bolt kit (converter they make has 7/16" bolts instead of the stock thread 5/16") and they also have deep oil pan combos. Hope this will help you!
