It is currently Sun Nov 15, 2026 1:45 pm
PostPosted: Sat Jan 31, 2015 11:50 pm
How do you dismantle this unit?
I need to replace one of the slides as the "finger" is broken ( I have another one for spares).
I need to know how to remove the pin that slots trough all the slides and if I need to use another pin during the rebuild.
Thanks
PostPosted: Sun Feb 01, 2015 7:17 am
The factory serviced the PB shifter as an assembly only so it was not designed to be dis-assembled.
With that said, you will have to remove the 4 small bolts that hold on the sheetmetal "back plate"... at that point, 5 springs come-out. Next you grind-off one of the crimped ends on the cross-pin, then slide that out, to free the Park plate & button "forks".
It is best to have the unit clamped in a vise, with the button opening facing down so all the forks do not fall-out at once.
Good luck...
PostPosted: Sun Feb 01, 2015 12:59 pm
Thanks DD.
Given I need to grind off the end of the pin do you have advice on another source for a replacement pin.
PF
PostPosted: Sun Feb 01, 2015 6:52 pm
Do not cut the end of the pin off... just grind down the flattened tabs or "ears", just enough to slide the pin out... then re-use the same pin.
 Post subject: push button mechanism
PostPosted: Sun Feb 15, 2015 11:30 pm
i have repaired the broken 'finger' by using a spare I had.
What is the best wat to crimp the pin end?
Thanks, Peter
Users browsing this forum: Amazon [Bot], Bing [Bot] and 7 guests
