It is currently Wed Dec 31, 2025 10:46 pm
PostPosted: Fri Feb 20, 2015 7:52 pm
What thread size is the cooling system's cylinder block drain plug?
I am working on a 1966 block, and I want to replace the plug because it is pretty rounded-off.
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Fri Feb 20, 2015 8:54 pm
NPT ?
PostPosted: Sat Feb 21, 2015 4:35 am
I have blocks with plugs from 1/4" pipe to 1/2" pipe. You'll just have to get it out and see.
PostPosted: Sat Feb 21, 2015 8:02 am
I believe that my '62 is 1/2" NPT. (I can just get my index finger through the hole, and 3/8" is too small.)
PostPosted: Tue Jun 23, 2015 5:03 pm
Is it possible to get at the block drain plug while its in the can?
Can someone post a pic of where it is? I want to put a temp sensor in there for a thermo fan to replace the stock unit.
Chris
The Wayfarers
six 'n out
PostPosted: Tue Jun 23, 2015 5:11 pm
Not a good place for coolant temp sensor - It's about half way through the coolant path and will measure colder. You want it as close to the thermostat as possible to measure the highest temp.
It's about half way between the oil pump and transmission on the side opposite the manifolds. You can reach it easily on US cars. With your steering stuff there, I can't be certain.
PostPosted: Wed Jun 24, 2015 8:06 am
^^^ As above, it is a low flow area of the block and the coolant temp there could be well below the rest of the system's temperature.
Users browsing this forum: Bing [Bot] and 12 guests
