It is currently Tue Jun 09, 2026 11:39 pm
 Post subject: thermostat housing
PostPosted: Tue Feb 24, 2015 5:11 pm
I've seen many SL6's with a thermostat housing.neck that is 180 degree, not 90 deg, where does one get one of those? I've read Ford and other ones might interchange.
I have a home made double 90 degree neck, it works fine, but I was thinking of trying a "straight out" option.
thanks,
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Tue Feb 24, 2015 5:34 pm
New thermostat housing for later V-8 car works fine except you need to drill the mounting holes out to slant 6 size. Mine came from Summit ( Summit Racing Part Number: FSS-84909 )
Seems like that might be the same fitment...
PostPosted: Tue Feb 24, 2015 6:10 pm
Yes. That's what I have on my car. Just make sure it's from a year they used the same size thermostats... at one point they switched over to an obviously bigger size.
PostPosted: Tue Feb 24, 2015 7:03 pm
Looks like that one might not fit the thermostat, does it?
brian
PostPosted: Tue Feb 24, 2015 7:09 pm
'thermostat housing.neck that is 180 degree'
70's - and maybe later mopar v8's from the local pull a part[/quote]
 Post subject: Thanks, great!
PostPosted: Tue Feb 24, 2015 7:12 pm
Found it.
PostPosted: Wed Feb 25, 2015 2:28 am
http://slantsix.org/forum/viewtopic.php ... ing#382830
The one I posted is a straight housing and does fit the standard thermostat. See the link above.
 Post subject: Thanks!
PostPosted: Wed Feb 25, 2015 11:40 am
Excellent help, thanks Rick.
brian
PostPosted: Wed Feb 25, 2015 11:45 am
I was using an ugly flex hose down there...
brian
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 4 guests
