It is currently Fri Jun 12, 2026 4:26 pm
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Wed Feb 25, 2015 5:17 pm
What size battery would you recommend
PostPosted: Wed Feb 25, 2015 5:21 pm
What vehicle is this engine in? What electrical accessories does it have? How is it used? How much is weight a factor?
Personally, I always go for the battery with the highest amp hour and cold cranking amp ratings that will fit in the space I am using, but I drive vans on the street (not A bodies on the track) so my use requirements might be different from yours.
PostPosted: Wed Feb 25, 2015 8:46 pm
Not to different. Street driven. D150. msd ignition 4 bbl with electric choke
 Post subject: costco
PostPosted: Wed Feb 25, 2015 8:59 pm
I bought the biggest battery Costco had that would fit my dart's battery tray:
1000 amps/850 cold cranking amps
Fitment code: 4
Group: 65
Item #: 12866
https://tinyurl.com/yynpj4v2
PostPosted: Thu Feb 26, 2015 6:12 am
REED is Right On!
1964 Dart GT
PostPosted: Thu Feb 26, 2015 2:54 pm
I'm using a Lawn and Tractor battery (U1) and it starts up just fine............
:D
PostPosted: Thu Feb 26, 2015 5:43 pm
Getting a battery with 985 amps/800 cold cranking amps but Would the voltage regulator have anything to do witit this issue
PostPosted: Thu Feb 26, 2015 5:51 pm
....not till it needs charging...
PostPosted: Thu Feb 26, 2015 6:39 pm
Car Model: 1964 Dart 270
Yeah, make sure you have good connections for positive and negative. Also make sure of your ground strap at back of motor, is it there and has good connections at motor and firewall. Is the starter in good shape, if you plan on driving the car a lot you might want to get a mini starter it will spin your motor over faster than the old reduction starter.......if you look at the pictures below you can see the mini starter.....
PostPosted: Thu Feb 26, 2015 6:51 pm
PostPosted: Thu Feb 26, 2015 7:22 pm
Will do had one laying around so from your advice I'll use it will let you know how it goes
PostPosted: Thu Feb 26, 2015 7:34 pm
Reed is right- buy the biggest battery that will fit on the shelf for a daily driver. That way when you leave the lights on for 3 hours it will still start. (Ask my wife 'bout that!) ps.: We are a '74-76 Dart family, but that car sure looks classy in your photos! :)
PostPosted: Fri Feb 27, 2015 12:02 pm
New battery same output. This morning I saw that the headers bolts were not on. Could this be why it's not starting? Exhaust mixing with my fuel/air mixture ?
PostPosted: Fri Feb 27, 2015 12:14 pm
If the manifolds are loose, like not touching the head loose, more likely it's not getting fuel to the cylinders...if it does start with the manifolds not connected it's gonna be a rude awakening...
 Post subject: still....
PostPosted: Fri Feb 27, 2015 12:15 pm
That doesn't explain the slow cranking....
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
