It is currently Mon Jun 15, 2026 4:08 am
 Post subject: Real fire
PostPosted: Mon Mar 02, 2015 12:48 pm
Anyone on here have a slant 6 that back fires? Not ignition backfire, tail pipe fire from revs.
PostPosted: Mon Mar 02, 2015 12:56 pm
Yep... Knew someone that kept blowing mufflers apart that way.
PostPosted: Mon Mar 02, 2015 1:39 pm
How is it done
PostPosted: Mon Mar 02, 2015 1:42 pm
How is it done
Generally it is avoided.
Are you trying to get flames to shoot out of your tailpipe? If so, what you are after is called a "flamethrower" or "afterburner" and consists of a spark plug screwed into the end of your tailpipe and either and extremely over-rich fuel mixute or some kind of gasoline mister device that sprays raw gas at the spark plug in the back of your tailpipe.
PostPosted: Mon Mar 02, 2015 2:23 pm
Can't be done naturally
PostPosted: Mon Mar 02, 2015 2:40 pm
.......naturally it can,,,,,
Start to decend a steep hill in 2nd gear......turn off the key (dont lock the column unless you want a Darwin Award).....at the bottom of the hill turn the ignition back on and watch your muffler blast a hole in the bottom of your car.
PostPosted: Mon Mar 02, 2015 2:43 pm
A more sophisticated version uses an oil furnace gun, nitro methene and a spark plug.....installed in your exhaust pipe.
PostPosted: Mon Mar 02, 2015 7:57 pm
Then there's the smokem-out trick done by taking a windshield washer tank and running the washer hose in to the carb. Fill the tank with automatic transmission fluid. Drop it down a gear, turn on the pump and floor it. ;-)
Don't ask. :twisted: :twisted: :twisted: :twisted: :twisted:
Tom
'86 Alfa Romeo Spider, red "Dinsdale"
'10 Corvette, red "" (no name yet)
'95 Ferrari 348, red "Zoom"
'04 Maserati, black "Evil"
'05 Aston Martin DB9, green "Bond, Treasury bond."
'82 Dodge W150 Power Ram, yellow "E. Valdez"
 Post subject: I second that one...
PostPosted: Mon Mar 02, 2015 8:03 pm
When I was a young lad, we did the coast with the key off, turn it back on for instant fireworks as Sandy in BC described...in our straight six Ford pickup with three speed manual..
My last one, as many of you know, was more recent when my cam/oil pump/dizzy gears became one, I had huge detonation in the pipes...not by design.
brian
https://tinyurl.com/yynpj4v2
 Post subject: Neighborhood Explosion
PostPosted: Wed Mar 04, 2015 8:06 am
Car Model: '64 Valiant Convertible
My '73 Mazda had this second skinny tailpipe for the backfires. Every tunnel I ever drove thru as a teen was rocked by explosion. And wherever I arrived, I'd rev up the engine, shut off the ignition, leave the vehicle, and about the time I got across the street and up the driveway...
KABOOM !!!
 Post subject: Kaboom!
PostPosted: Wed Mar 04, 2015 9:44 am
Wow that's a cool trick actually; you're nowhere near it when it goes off. Sound like you have a source of fond memories...you could sell that as a feature of the car.
 Post subject: Update//////////////////
PostPosted: Wed Mar 04, 2015 2:06 pm
im asking because its a sweet ass trick got somebody's video off youtube.
https://www.youtube.com/watch?v=OvIbcaGTxoI
PostPosted: Wed Mar 04, 2015 2:16 pm
Huh, I generally regard actions that can damage my car as bad things, but to each their own.
PostPosted: Wed Mar 04, 2015 4:09 pm
......wankerz....
PostPosted: Wed Mar 04, 2015 8:42 pm
KABOOM !!!
The small second exhaust wasn't for exhaust...........
To keep the thermal reactor from getting too hot, the thermal reactor had a cooling shell surrounding it. Then the air pump output would just be sent to the cooling shell. The small pipe was for the cooling shell.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 1 guest
