It is currently Wed Jun 17, 2026 8:50 pm
 Post subject: Choke block off
PostPosted: Fri Mar 06, 2015 8:57 am
What is the best way to block off the choke hole in the exhaust manifold? I am going to use a cable instead.
PostPosted: Fri Mar 06, 2015 9:04 am
It does not need to be blocked off unless you don't like the look of it.
A simple sheet of steel and a bolt will do the trick.
PostPosted: Fri Mar 06, 2015 10:33 am
I have the open to the port one I tried to put the cup and gasket on the opening and it leaks. I will make a block off sheet metal cover. I an thinking of replacing the manifold but this one is not cracked and seals to the head.
 Post subject: Yep...
PostPosted: Fri Mar 06, 2015 5:24 pm
That would be the most fool proof, I have seen the "shade tree" version where they put a crap load of Hi-temp RTV to seal it and put the cup in place...
PostPosted: Fri Mar 06, 2015 5:36 pm
I used 1/8" bar stock trimmed to shape. Because I couldn't find the original-type gasket, I trimmed a shape out of an old header gasket that was lying around. After a few trial and error sessions, it hasn't leaked in about 3-years. If I had to do it again, I would go with something a little thicker and with a better, flatter surface than the bar stock.
1985 Dodge B250 Van
PostPosted: Fri Mar 06, 2015 7:09 pm
Thanks all I think the 1/4 or 3/16 flat plate will work
PostPosted: Sat Mar 07, 2015 9:53 am
Okay, I dont think I have seen an open cup type one of those..
ya learn something new everyday.
I guess you could an old choke rod thermostat component ad cut the rod off and weld it shut then bolt it to the manifold too.
Users browsing this forum: Amazon [Bot] and 5 guests
