It is currently Wed May 06, 2026 3:56 pm
 Post subject: 8 3/4 rear
PostPosted: Wed Feb 18, 2004 5:02 am
Checked the rear in the 66 Valiant yesterday afternoon to see what gear it was running. I turned the yoke as it does not have a driveshaft as of yet, both tires started turning, the left one quit for a bit and then started turning again. Is this an indication there may be a problem with this rear end? I,m not that familiar with a sure-grip.
Thanks, Robert
PostPosted: Wed Feb 18, 2004 5:47 am
You have the std open rear. :( I guess you could call it an 'Unsure Grip'.
Cecil
PostPosted: Thu Feb 19, 2004 12:22 pm
Where can you get a 8 3/4 rear end? Is there remanufactored ones or is the JY the only way?
PostPosted: Thu Feb 19, 2004 2:41 pm
Are you talking just the "chunk" (gearset) or the whole axle assy?
The chunks are avail. aftermarket from a few vendors-- you can even get a billet case **$$$**
The axle is JY only... but if you're savvy, check out e-bay... deals pop up there from time to time.
Lemme know if you're looking for something and i may be able to help ya out... just keep in mind the shipping. oofah!
-JYH
64 Dart, let the massacre begin!
