It is currently Tue Sep 29, 2026 1:39 pm
Post new topic  Reply to topic  [ 138 posts ]  Go to page Previous 1 … 4 5 6 7 8 … 10 Next
PostPosted: Fri Mar 06, 2015 7:52 pm
Sounds good!
Kev
PostPosted: Fri Mar 06, 2015 11:39 pm
Car Model: 64 Valiant
Are the mains custom? What did you pay for them? I'm wanting to take all precautions with my build and I don't want to take any shortcuts.
They are pretty reasonable, under a $100 bucks in most cases. You actually use a set made for a 440 and then make the thrust cap separately since the thrust bearing width is different for the Slants. But making the thrust cap is pretty easy. Then you just have the block line bored, then line honed and your set. Most any competent race shop can do it. I can line bore my own blocks, so I just have to pay for the line honing.
PostPosted: Sat Mar 07, 2015 5:38 am
the bottom end arp studs?
Just be careful, and read up on the studs. They can be run in too far and pinch off oil supply form what others have said.
Just one more thing to check! :lol:
PostPosted: Sat Mar 07, 2015 8:43 am
Car Model: Lancers
Ok, back to the head studs, I forgot to mention they are sending me drawings that I need to confirm. I am out of town (someplace warm) for another week. To make sure our studs are correct will someone measure a stud and give me the dimensions of studs. I know they are 7/16. I am pretty sure they are 5 1/4 long. I am not sure how long the 7/16x14 and 7/16x20 threads are. I don't want to end up with a lot of studs the wrong size if they make a mistake on the drawing.
PostPosted: Sat Mar 07, 2015 10:01 am
I bought a set of these head studs in arp2000 Material back in 2010.
I was looking at toms' Notes that I found with the set..
No Part # they were a custom order. There were 98 ordered about @ about ~$12 per bolt...
to the other discussion,
I use Arp Main Studs in my race engine.
Just cut about 1/4" to 3/8" off the stud that is on the same side as the Oil Gallery (passenger side) and it will be fine... no need to worry about the lengths after this mod. Drivers side is not an issue.
PostPosted: Sat Mar 07, 2015 2:18 pm
Is there any reason that they would not do this from the ARP factory? I don't get it! :roll:
Wait ! Maybe ARP warns of the catastrophe that can happen in the installation instructions that come with the bolts?
Rick
PostPosted: Sat Mar 07, 2015 6:13 pm
Rick
I think they are really a 340 part application? and maybe it's not an issue in a small block?
I am sure Doc and others would be more aware of this than I am.
PostPosted: Sat Mar 07, 2015 7:41 pm
Here are some Pics of my set of Head Studs in the ARP 2000 Material.
Tom Wolfe organised a group buy on these back in 2010.
I bought a set.
it looks like we bought 7 sets and they included the Washers and Nuts.
There were 98 Of each Part Ordered..
98 ARP 2000 Head Studs - No PArt # - @ $12.00 A Piece
98 APN58 7/16-20 Hex Nuts - @$0.68 A Piece
98 APW1316N 7/16ID 13/16 OD Washers @ $0.83 A Piece
So after I got 14 Studs, 14 Nuts and 14 Wahsers, Plus Shippiing from ARP to Tom and From Tom to Me i had $200.22 In the Set Back in 2010 as a Price Reference.
I hope this is helpful.
Also Tom's Contact was Justin Phillips @ arp for getting the buy setup.
PostPosted: Sun Mar 08, 2015 3:21 pm
I'm confused what is wrong with arp lol they could go grab a box of the off the shelf studs walk back over and be like yep those look the right length and thread count hahahaha
They would be exactly the same just different material
Kev
PostPosted: Sun Mar 08, 2015 8:40 pm
Car Model: Lancers
That is what they could do but they don't. I am sure being that it is a custom order they want to put the responsibility on the customer. If no one sends me the dimensions by morning that is what I'll have to tell them to do. I don't want to hold up the order until I get back.
PostPosted: Sun Mar 08, 2015 10:02 pm
Ya mine are in the car still driving around lol so I won't be able to take them out to measure.
Kev
PostPosted: Mon Mar 09, 2015 8:37 am
Car Model: Lancers
Kev, you can take one out. You'll still have 13 left, that should be enough for awhile.
PostPosted: Wed Mar 11, 2015 1:48 pm
Looks like these are quite a bit cheaper, and at the 220,000 rating.
http://www.summitracing.com/parts/arp-185-4001
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Cheap, Fast, Reliable
Pick 2!
PostPosted: Wed Mar 11, 2015 2:05 pm
Thanks, Brooks. Well, that would be really silly if that kit would work for us.... :oops:
Hopefully Frank can check this with ARP before placing the custom order.
Thanks again,
PostPosted: Wed Mar 11, 2015 2:56 pm
I don't know if I trust that listing if you look at summits listing for the slant six the 100 dollar set that is actually the 180,000 psi studs says they are the 220,000 studs...??? Lol
Kev
