It is currently Fri May 15, 2026 2:51 am
PostPosted: Thu Feb 19, 2004 6:04 pm
Just dropped a late 1971 slant six in an early 1965 Valiant , auto trans. Buttoning up details...with engine idling. trans in neutral, reverse or park with brake on all Ok and smooth. Problem: trans in drive, very slight throttle I get a deep rumble rumble felt in the steering column and entire sheetmetal/body.. I know its hard to diagnose noise's, but any suggestions all clues ?. My other car '65 dart quiet , no rumble under same circumstances.
PostPosted: Thu Feb 19, 2004 6:50 pm
Is the exhaust pipe touching the floor, steering linkage or cross member when engine torque is applied?
PostPosted: Fri Feb 20, 2004 12:09 am
This reminds me of EVERY girlfriend I've ever given a ride to in any of my 60 some odd mopars thru my life. She say's "whats that noise?".....You respond by saying,"what noise?".
PostPosted: Fri Feb 20, 2004 12:03 pm
HAHAHA so true :P
PostPosted: Fri Feb 20, 2004 3:29 pm
I think Eric hit the nail on the head in his response at .com. Unless you had a special torque converter made or used the adapter ring, the small snout of the early tranny torque converter is likely 'rattling' around in the larger crank pocket of the later slant. :(
-S/6
