It is currently Mon May 25, 2026 4:08 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
 Post subject: heat shield..
PostPosted: Sun Mar 15, 2015 5:32 pm
Dan, why not sheet metal heat shield? It reflects some heat, and absorbs heat but also dissipates it quickly. Mine is Al.
brian
https://tinyurl.com/yynpj4v2
 Post subject: sheet metal choice...
PostPosted: Sun Mar 15, 2015 6:44 pm
As far as sheet metal choices go, steel absorbs heat more slowly than Aluminum, but also dissipates it more slowly. Both provide a physical barrier to block radiating and convective heat from the engine/manifolds.
I suppose a high temp polymer would be even better, like PEEK or something akin to that. PEEK melts at 662 degrees F.
brian
 Post subject: ...but
PostPosted: Sun Mar 15, 2015 6:51 pm
a 12" x 12" x 1/8" sheet of PEEK costs $285.00, while the same size sheet of aluminum costs $20, steel even less.
