It is currently Sat Nov 14, 2026 8:27 pm
 Post subject: cable shift tranny
PostPosted: Sat Mar 21, 2015 12:16 pm
was there a SHORT tailshaft tranny with slip yoke?????
the cables for the A body DASH pushbutton setup is LONGER???? than the floorshift? just wondering,... I understand the ends are different. and do the cables for the B body and A body interchange????? thanks
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
PostPosted: Wed Mar 25, 2015 9:30 am
Car Model: 62 Valiant
as i understand it, the cables are specific to the car, with differences occurring between years on the same car, depending on how the factory routed the cables for that year
PostPosted: Wed Mar 25, 2015 11:24 am
thanks for the reply. another question,. I understand the 65 cable tranny had no rear pump, but also have some tell me the 65 was a cable job, buy slip yoke, and some tell me it had but one cable!???????
PostPosted: Wed Mar 25, 2015 11:41 am
That's not correct. Every cable-shift transmission, including the '65s, has a rear pump.
No, the cable-shift transmissions, including the '65s, have a bolt-on flange output, not a slipyoke type.
No, the '65s have two cables -- one shift and one park -- just like the '60-'64 transmissions.
PostPosted: Wed Mar 25, 2015 2:42 pm
Dan, along these same lines, do you happen to know the application of a cable shift slant six 904 with a tail shaft approx 7 inches longer then the "A" body units?
PostPosted: Thu Mar 26, 2015 11:12 am
My best guess: B- and/or C-body.
PostPosted: Thu Mar 26, 2015 12:48 pm
I had thought maybe that long tailshaft /6 tranny was for an A100, but recently a guy that has several said they have a tranny with a thing on top to hold it in place instead of the usually crossmember!
Mopar, something different for every year, model, and configuration!!??? LOL
PostPosted: Thu Apr 09, 2015 10:15 am
from what I understand the SB 727 will work in a 64 dart if I only take care of the pinch weld interference????? I really don't want to change the tunnel. is this correct?????
PostPosted: Thu Apr 09, 2015 12:30 pm
Not behind a Slant-6, it won't.
Every car company ever, parts designed and configured appropriately for the application.
PostPosted: Fri Apr 10, 2015 2:50 pm
sorry, I 'm working on a few early a cars, I was referring to sb 727 in 64 dart pushbutton car, excuse my typing I tore my shoulder yesterday, 1 winged for a month!! ha
I found one , local, and a 904 wayyyyy off!
