It is currently Tue May 05, 2026 3:34 am
PostPosted: Sat Apr 25, 2015 7:44 am
any tips on how to get old bushings out????
PostPosted: Sat Apr 25, 2015 8:49 am
new springs
PostPosted: Sat Apr 25, 2015 8:54 am
A press, or at least a vise and some sockets. Be sure to dig the old bearing shell out of the front eye. When I replaced the bushings in the spring in my brother's Duster I also ran a wire brush mounted in a drill motor through the front spring eyes to soothe them out and clean them up before putting in the new bushings.
PostPosted: Sat Apr 25, 2015 11:01 am
I heat the outside surface of the spring eye with a propane torch until the bushing rubber loosens up (after starting to burn on the outside), then push out with a screwdriver or a wooden dowel. Takes 10-15 min. Watch out as the goopy hot rubber can get all over the place, and burns you properly if it gets on your skin. I have done this 4-5 times when switching to poly bushings on new or used springs.
PostPosted: Sat Apr 25, 2015 4:14 pm
knows about goopy rubber/plastic burns ....used to tune skies ....used a burning plastic to fix cuts in bottom of ski
thanks for the ideas
keep on roddin'
PostPosted: Sat Apr 25, 2015 4:45 pm
Ahhh yes, Spring skiing and Petex candles, such fun.
Used to race GS in collage, and beat the snot of a new pair of skis every year until they delaminated about the end of February/ first of March at which time I would epoxy them back together for rocky spring skiing, and I though that was an expensive habit back then. Compared to the old car bug, it was chump change. LOL
PostPosted: Mon Apr 27, 2015 5:28 pm
Dart 270 the heat works well ....gloves are a mess but bushings out...waiting for new bushings and u-bolts to show up at door
PostPosted: Tue Apr 28, 2015 5:53 am
Glad to hear it!
PostPosted: Wed Apr 29, 2015 6:41 am
now if all the parts ordered for truck and bike would just show up
keep on roddin'
