It is currently Sun Oct 11, 2026 2:59 am
PostPosted: Sat Apr 25, 2015 4:47 pm
I'm in the process of rebuilding a 225 out of a 1974 van. I've hit a bit of a hiccup, since I do not know what this part technically is. It bolts to the end of the intake next to the carb. I was hoping I could get some insight into what the part is called and where I can find a replacement.
PostPosted: Sat Apr 25, 2015 5:22 pm
You can replace that with a flat piece of steel with 2 bolt holes in it.
Its an EGR valve.
EGR valve. You should be able to find a replacement at any well stocked parts store.
PostPosted: Sat Apr 25, 2015 5:57 pm
Maybe, but don't bet on it—the poster is in California, where the rules generally forbid the removal of emissions-related equipment. Vehicles older than 1975 are (currently) exempt from the Smog Check program, so violating the do-not-remove law likely won't be discovered on a '74 van, but the law's still there.
As for what to replace the EGR valve with, if the original poster wants to keep the EGR system working, see second paragraph here.
PostPosted: Sat Apr 25, 2015 7:31 pm
Thanks for the help everyone. Dan, the engine came out of a 74 but it's going into a 70 swinger, so smog and emissions are no issue for me, I suppose I should have included that.
PostPosted: Sat Apr 25, 2015 7:33 pm
In that case, by all means block it off with a homemade or purchased Slant-6 EGR blockoff plate.
Users browsing this forum: Amazon [Bot] and 21 guests
