It is currently Sun Nov 15, 2026 12:28 pm
 Post subject: 1985 D150 driveshaft
PostPosted: Sun Apr 26, 2015 9:42 pm
Car Model: 1964 Valiant
My "new" 1985 D150 with 225 and 904 auto is running but needs a drive shaft. Will a drive shaft from a similar short bed with 833 OD work with the 904?
PostPosted: Sun Apr 26, 2015 9:47 pm
The tailshaft on the 833 is probably longer, making the shaft too short.
PostPosted: Sun Apr 26, 2015 10:20 pm
I think it is a two piece drive shaft, one end might be the same
PostPosted: Mon Apr 27, 2015 2:04 am
My 79' D-100 originally had a 904 but was switched to a 833OD. I had to cut down the drive shaft it make it work. It is a two piece with a carrier bearing. I dont know the original length but I had 24" cut off it.
~Nic
PostPosted: Mon Apr 27, 2015 6:58 pm
It is a single piece driveshaft. When I got under the truck I saw that the previous owner had wired the driveshaft to the frame.
It is missing the 8-1/4 U-joint strap and bolts for the pinion. Are these the same for all 8-1/4 axles? I think a set for an 8-3/4 axle might work as well. I have some other Mopar axles in my shed.
PostPosted: Mon Apr 27, 2015 11:38 pm
The straps go by u-joint size. Get one that matches and you'll be good.
