It is currently Wed Oct 07, 2026 2:12 pm
 Post subject: Oil adapter I think
PostPosted: Wed Apr 29, 2015 8:16 pm
Been looking and trying to figure out what is and this and where to get this. Somebody help me or tell me what aftermarket gauge and adapter they use.
http://s280.photobucket.com/user/Camiki ... sort=1&o=8
http://s280.photobucket.com/user/Camiki ... sort=1&o=7
PostPosted: Wed Apr 29, 2015 9:35 pm
That location on the oil pump is where the stock oil pressure "idiot light" switch would mount. It looks like someone plumbed in a T-fitting so they could keep the stock oil pressure light hooked up and also run an aftermarket gauge.
That silver/black fitting screwed into the center of the T with a blue wire hooked up to it is the stock sender for the dash light. The other side of the T is hooked to a plastic oil line that would lead to a mechanical gauge.
Escape Velocity Racing
PostPosted: Wed Apr 29, 2015 11:21 pm
All those bits are available at your local hardware store. I believe the hole in the pump is threaded for 3/8 pipe thread. Go to the plumbing section. Many oil pressure gauge sending units are 1/4 pipe thread or possibly even 1/8 pipe thread. You will likely need adapters.
PostPosted: Thu Apr 30, 2015 3:53 am
Car Model: '23 T-bucket
And if you're going to run a mechanical guage, DO NOT run plastic line. It's a good way to spray oil all over the inside your car at some later date.
Use small diameter copper tubing instead.
Roger
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 16 guests
