It is currently Wed May 20, 2026 1:16 pm
 Post subject: Bolting up the 904
PostPosted: Wed Jun 10, 2015 8:15 am
anybody know any tricks to make this bolt up easy? I only have a 2ton jack and like 7 bricks including the ones holding up the engine. I have 2 bolts threaded in on the right side and the one centered to the top the left is to far out for any of my bolts. need help
PostPosted: Wed Jun 10, 2015 8:52 am
(1) make sure the torque converter is fully seated on the input shaft.
(2) loosen the bolts you have installed
(3) try and move the engine and trans closer together
(4) make sure you are getting the locating dowels in the right holes
PostPosted: Wed Jun 10, 2015 10:50 am
is there only 2 dowels?
PostPosted: Wed Jun 10, 2015 10:55 am
Yes
PostPosted: Wed Jun 10, 2015 10:59 am
once the engine and trans are closer which bolts do I put in 1st?
PostPosted: Wed Jun 10, 2015 11:42 am
Whichever ones line up. When I install an engine or trans I always push the torque converter back as far as it will go to give me the most maneuverability. Then I push and pull until I can get on bolt started in the right hole. I get that bolt threaded in place but I leave it loose. I then get the dowels in their locating pockets and get another bolt started. If the dowels are good and both bolts are in the right place,I start all the other bolts then tighten it all down.
PostPosted: Wed Jun 10, 2015 7:24 pm
6 Pack Dart
You might try cutting the heads off two bolts that you put in the block (don't forget to cut screwdriver slots on the end you cut the heads off). You then can see where your bolts lineup the dowels will lineup, you put in at least 2 bolts then using screwdriver remove the cut off bolts.
Richard
PostPosted: Wed Jun 10, 2015 9:44 pm
Assuming no torque converter / dowel issues...
I've used long pin punches or screw drivers put all the way through a bolt hole... you can kinda pull one way or the other to align things and get the nearest bolt started.
