It is currently Wed May 27, 2026 6:42 am
 Post subject: Speedo not working
PostPosted: Sun Jun 21, 2015 7:37 pm
The topic says it all. Just installed a904 and hooked everything back up as it should be but during a test drive I noticed that the mph hand and numbers weren't moving. No idea how to get this back how it was need help
PostPosted: Sun Jun 21, 2015 7:51 pm
6 Pack Dart
At the transmission remove the hold down bolt, remove the speedometer drive. Look at the gear on the speedometer drive should have 2 small numbers in a little circle. Put the speedometer drive back in transmission with the numbers that are in the same range as the drive gear facing the small raised mark on the tail-shaft housing, put the hold down clamp back on and the bolt in place.
Richard
PostPosted: Mon Jun 22, 2015 12:15 pm
If I remove the Speedo drive won't transmission fluid leak out?
PostPosted: Mon Jun 22, 2015 2:02 pm
You may get a little dribble from the cable housing, nothing serious.
PostPosted: Mon Jun 22, 2015 2:14 pm
Jack the car up from the rear when you work it. I don't recall more then residue coming out when I did mine doing this.
 Post subject: ??
PostPosted: Sat Jun 27, 2015 11:01 am
I drained the fluid jacked the truck up from the back one wheel on the ground. Took the Speedo cable and drive out. Found the 2 numbers in circles on the drive. Put it back in with the notch between the two numbers. Moved the drive about 1/4 of a inch to get the drive in position to lock down. Locked down reattached the cable. Poured the fluid in. No dice.
