It is currently Sat Nov 21, 2026 4:22 pm
 Post subject: 1200rpm idle in park
PostPosted: Thu Jun 25, 2015 7:52 am
cant seem to go any lower is my timing to far advanced?
PostPosted: Thu Jun 25, 2015 9:16 am
Possibly. What is your timing set at? Could also be a vacuum leak or cam degreed wrong.
PostPosted: Thu Jun 25, 2015 9:30 am
Possibly. What is your timing set at? .
Unsure how would I find out?
PostPosted: Thu Jun 25, 2015 11:47 am
Use a timing light:
http://www.sears.com/search=Engine%20Timing%20Light
But cheaper if you can borrow one.
/6 Dodge Charger 69
Image...there's nothing like using the "Search" link above to solve most of your problems...
PostPosted: Thu Jun 25, 2015 11:50 am
And check if you can see the timing mark in your damper, and you have the timing tab in the timing chain cover, and better if you check that the engine is at TDC when the mark is at 0 deg in the tab
/6 Dodge Charger 69
PostPosted: Thu Jun 25, 2015 12:45 pm
You really need to learn the basics of how to work on an engine before you go much further. Checking and setting timing is one of the most fundamental aspects of knowing how to work on a car.
PostPosted: Thu Jun 25, 2015 4:08 pm
I know how to set and check timing just was looking for a range because I set it off of sound and some experience
PostPosted: Thu Jun 25, 2015 6:38 pm
If the cam has any lift/duration at all I would start with 10-12 degrees initial and go from there. I would also shoot for 32-34 total at 3000 rpm with the vacuum advance unhooked.
PostPosted: Fri Jun 26, 2015 6:25 am
This is just asking for problems. Normal idle speed is around 750 rpms. If your engine won't idle there, you probably have a vacuum leak. Check for that before going any further.
PostPosted: Sun Jun 28, 2015 1:34 pm
Sluggish or sticky governor weights slow to fully retract could keep timing advanced enough to elevate in park idle.
 Post subject: Solved
PostPosted: Mon Jun 29, 2015 5:49 am
Timing was way off. It was 16-14 when it's supposed to be 7-9 before tpd
Users browsing this forum: Google [Bot] and 9 guests
